WAN over Wifi
cybernik
in Home Router
hello to group, i would like to connect my VGM1312-B10D router via wifi to the main wifi router of the house. the VGM is in the garden - cannot use ethernet.
Subsequently, I need to connect an ethernet only device to the VGM1312 router lan ports to have access to internet. I have tried with the WDS screen but have not been successful. Could anybody outline how can i achieve this?
thank you
Hi there, not sure how you set the WDS on VMG1312-B10D, maybe you can share how you set this function.
On the other hand, WDS function normally suggested to use the same model (the same WIFI chip and software) to avoid compatibility risk and also for better performance.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
