"Code" formatting is working as intended?
mMontana
mMontana Posts: 1,446 image  Guru Member
edited March 2024 in Community Feedback
Last post i tried to do lead me to unpleasant result with code feature.
These are rows from my windows command prompt.
>ping 192.168.40.1 -n 10
Esecuzione di Ping 192.168.40.1 con 32 byte di dati:
Risposta da 192.168.40.1: byte=32 durata=40ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=33ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61
Statistiche Ping per 192.168.40.1:
    Pacchetti: Trasmessi = 10, Ricevuti = 10,
    Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
    Minimo = 33ms, Massimo =  40ms, Medio =  34ms
If i apply code this seems the result.
<div><br></div><div>ping 192.168.40.1 -n 10<br><br>Esecuzione di Ping 192.168.40.1 con 32 byte di dati:<br>Risposta da 192.168.40.1: byte=32 durata=40ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=33ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br><br>Statistiche Ping per 192.168.40.1:<br>&nbsp;&nbsp;&nbsp; Pacchetti: Trasmessi = 10, Ricevuti = 10,<br>&nbsp;&nbsp;&nbsp; Persi = 0 (0% persi),<br>Tempo approssimativo percorsi andata/ritorno in millisecondi:<br>&nbsp;&nbsp;&nbsp; Minimo = 33ms, Massimo =&nbsp; 40ms, Medio =&nbsp; 34ms<br></div>
  • Zyxel_Carter
    Zyxel_Carter Posts: 62 image  Zyxel Employee
    First Comment Friend Collector Eighth Anniversary
    @mMontana
    I copy your wording and past but without met the problem.
    Are you copy from cmd directly? May you copy wording to a text file then past it in the code field again?
  • mMontana
    Selecting output from command prompt. Copy.
    Paste it into post frame. Selected the text. Applied "code" formatting.
  • Zyxel_Carter
    It can be duplicated by your step, thanks for reporting and we are trying to fix it now.
    For the short-term solution, you can select "code" format first and then past the wording in the field, it can work normally.
Leave a Comment
Rich Text Editor. To edit a paragraph's style, hit tab to get to the paragraph menu. From there you will be able to pick one style. Nothing defaults to paragraph. An inline formatting menu will show up when you select text. Hit tab to get into that menu. Some elements, such as rich link embeds, images, loading indicators, and error messages may get inserted into the editor. You may navigate to these using the arrow keys inside of the editor and delete them with the delete or backspace key.
