How can i backup running config in a switch using ssh script?
I want to make backups from my switch configs, and i want to use an ubuntu machine with cron for this task, so i can automate it.
My switch is a XGS1930-28HP with firmware version 4.5(ABHS 7.1)
I want to use this command in my script to ssh to the switch:
sshpass -p "password" ssh -o StrictHostKeyChecking=no admin@SWITCH_IP COMMAND
My command would be show run, and then i wopuld capture it, and save it a in file.. but i cant use any command with this, because when i try to use it, the switch return me this error:
Received disconnect from SWITCH_IP port 22:2: invalid command run.
Disconnected from SWITCH_IP port 22
So, please help me, how can i automate taking backup from my switch configs?
Thanks.
Thanks.
You put "show run" between quotes?
Just saw another post also about this and seems having workaround there.
https://community.zyxel.com/en/discussion/3401/gs1920-24hpv2-non-interactive-ssh-invalid-command
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 668 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
