"Code" formatting is working as intended?
mMontana
Last post i tried to do lead me to unpleasant result with code feature.
These are rows from my windows command prompt.
>ping 192.168.40.1 -n 10
Esecuzione di Ping 192.168.40.1 con 32 byte di dati:
Risposta da 192.168.40.1: byte=32 durata=40ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=33ms TTL=61
Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61
Statistiche Ping per 192.168.40.1:
Pacchetti: Trasmessi = 10, Ricevuti = 10,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 33ms, Massimo = 40ms, Medio = 34ms
If i apply code this seems the result.
<div><br></div><div>ping 192.168.40.1 -n 10<br><br>Esecuzione di Ping 192.168.40.1 con 32 byte di dati:<br>Risposta da 192.168.40.1: byte=32 durata=40ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=33ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=35ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br>Risposta da 192.168.40.1: byte=32 durata=34ms TTL=61<br><br>Statistiche Ping per 192.168.40.1:<br> Pacchetti: Trasmessi = 10, Ricevuti = 10,<br> Persi = 0 (0% persi),<br>Tempo approssimativo percorsi andata/ritorno in millisecondi:<br> Minimo = 33ms, Massimo = 40ms, Medio = 34ms<br></div>
@mMontana
I copy your wording and past but without met the problem.>ping 192.168.40.1 -n 10
Are you copy from cmd directly? May you copy wording to a text file then past it in the code field again?
Selecting output from command prompt. Copy.Paste it into post frame. Selected the text. Applied "code" formatting.0
It can be duplicated by your step, thanks for reporting and we are trying to fix it now.For the short-term solution, you can select "code" format first and then past the wording in the field, it can work normally.0
Leave a Comment
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 511 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
