USG40 firmware 4.60 unavailable
SoluzioniDigitali
in Security
Hello, my firewall usg 40 has version 4.38 (AALA.0).
I want to update to version 4.65. Is it advisable to install 4.60 or can I install 4.63 and then 4.65, directly from 4.38?
Obviously after having done the necessary checks.
Thank you .
It should be ok to go to 4.65 backup your config if it gose wrong or at the worse will not boot you can do a reset and load 4.38 slot with your config or after a reset with 4.65 apply your config with Ignore errors and finish applying the configuration file.
Welcome to Zyxel community.
You can update firmware from V4.38 to V4.65 directly.
To avoid unexpected error occurs, you could backup current startup-config before updating the firmware, just as @PeterUK mentioned that.
Thanks.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
