USG40 firmware 4.60 unavailable
SoluzioniDigitali
SoluzioniDigitali Posts: 6 image  Freshman Member
First Comment Seventh Anniversary Nebula Gratitude
Hello, my firewall usg 40 has version 4.38 (AALA.0).
I want to update to version 4.65. Is it advisable to install 4.60 or can I install 4.63 and then 4.65, directly from 4.38?
Obviously after having done the necessary checks.
Thank you .
    PeterUK Posts: 4,426 image  Guru Member
    It should be ok to go to 4.65 backup your config if it gose wrong or at the worse will not boot you can do a reset and load 4.38 slot with your config or after a reset with 4.65 apply your config with Ignore errors and finish applying the configuration file.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @SoluzioniDigitali
    Welcome to Zyxel community.
    You can update firmware from V4.38 to V4.65 directly.
    To avoid unexpected error occurs, you could backup current startup-config before updating the firmware, just as @PeterUK mentioned that.
    Thanks.
