USG Flex IPOE/Routing
Pook
Pook Posts: 151  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
Hi Everyone
Replacing a ZyXel router attached to a Virgin Media Hub in Modem Mode. Router is currently set to IPOE and Routing. Will leaving the USG Flex in DHCP mode be ok as it does not have these options for the WAN?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    edited August 2021 Answer ✓
    @Pook
    Yes, you can leave the USG Flex in DHCP mode for the WAN setting as below:
  • Pook
    Should anyone else need to know it works fine just leaving the USG Flex in DHCP mode for the WAN.
  • Zyxel_Charlie
    @Pook
Nebula Tips & Tricks
