Jason
When Do We Use Nebula Cloud Controller and when we use nebula orchestrator?
businessuer
in Nebula
What is the difference between these 2 and when do we use them?
Hello @businessuer ,
Both systems provide centralized management of equipment.
Nebula Orchestrator mainly supports Gateway and SD-WAN functions (wan optimization). For details, please refer to our datasheet.
Nebula Control Center supports not only gateway (but no SD-WAN function) but also Switch and AP (support list)
Since the supported models on both sides are different, the device and license need to be purchased separately.
Hope it helps.0
Hope it helps.Jason0 -
What is the difference between SD wan and cloud management?
I thought they are the same?0 -
Hi @businessuer
The SDWAN solution supports some additional features which is targeting on internet quality and reliability. For example: Dynamic Path Selection (DPS), WAN Optimization.
For more information, please refer to here
Nebula solution provides easy to manage portal which helps users to complete the network deployment not only on the Gateway settings, but also on switch and wireless solution.
- 603 USG FLEX H Series
- 481 News and Release
