Setup instructions for PK5001Z modem router
BrianS
in Home Router
I would like to download a PDF copy of the installation/setup instructions for a ZyXel K5001Z Modem Router. Is there a document out there for this modem/router
Hello @BrianS
Do you mean modem PK5001Z?
If yes, then the following link might help you https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-pk5001z.html as there are set-up instructions there for CenturyLink ISP.
Kind regards,
Tony0 -
Hello @BrianS
The quick start guide for the PK5001Z modem is at https://fccid.io/pdf.php?id=1633416 currently.
Kind regards,
Tony0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
