VOIP on ATP200
Testing VOIP access from behind an ATP200 and I get the following error:
Voip Tester failed to make a SIP call.
Check the following:
- External firwall may need to allow the SIP and RTP ports
- Disable router SIP ALG
What do I need to adjust to get this to work? I've made no known changes to SIP from factory defaults. This has the latest 5.02 firmware, if that makes any difference. I checked the ALG section and Enable SIP ALG is NOT checked.
Sorry, but I found out that this was a misconfiguration on the VOIP test, not the firewall. This is resolved.1
Hi @BMS,Can you post a brief network topology with caller, callee, and sip server marked, it would be helpful to understand about call flow.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
