Is There A Way To Get Switch Port Information Of AP When It WAS Online
When last time it online, we can see the neighbor info and switch port information.
Now it offline, we cannot see the switch port it is connected to.
How to check where the AP connected to when it WAS online?
Hi @businessuer
If the AP is still connecting on switch, you can go to Site-wide > Monitor > Topology to check the port information.
And if your switch is online on Nebula, another way is going to Switch > Monitor to check the ports to find which the AP is connecting.
Thank you
Regards,
Bella
It is offline. I want to know the port it WAS connected to.
以前!0 -
Hi @businessuer
Yes, the methods above is the case that AP still connecting on switch but went offline status on Nebula case. But if the AP is not plug-in on switch, the port it was connecting will be can’t checked.
May I know the scenario or requirement that you have to look into the port that AP was connecting?
Thank you
Regards,
Bella
We have a lot of AP.
one year later one or two of the ap no good.
We want to check which port it last time connected to but no information.
We hope zyxel can implement some feature so we can check this information.0 -
Hi @businessuer
Thanks for the suggestions.
If you have AP problem, feel free to tell us the symptom for advice.
We can take a look in your Nebula site.
Regards,
Bella
Hope you implement this feature.
Tell you ap was last time connect to which port before offline.0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 690 USG FLEX H Series
- 363 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 504 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 112 Security Highlight
