When Do We Use Nebula Cloud Controller and when we use nebula orchestrator?
businessuer
businessuer Posts: 134 image  Ally Member
What is the difference between these 2 and when do we use them?
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hello @businessuer ,
    Both systems provide centralized management of equipment.
    Nebula Orchestrator mainly supports Gateway and SD-WAN functions (wan optimization). For details, please refer to our datasheet.
    Nebula Control Center supports not only gateway (but no SD-WAN function) but also Switch and AP (support list)
    Since the supported models on both sides are different, the device and license need to be purchased separately.
    Hope it helps.
    Jason
  • Zyxel_Jason
    Hope it helps.
    Jason
  • businessuer
    What is the difference between SD wan and cloud management?
    I thought they are the same?
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @businessuer
    The SDWAN solution supports some additional features which is targeting on internet quality and reliability. For example: Dynamic Path Selection (DPS), WAN Optimization.
    For more information, please refer to here
    Nebula solution provides easy to manage portal which helps users to complete the network deployment not only on the Gateway settings, but also on switch and wireless solution.
Nebula Tips & Tricks
