License Nebula
Evert
I received a mail that my license to Nebula is almost ending.
I do have a couple of questions:
* Does my access point still work if i do not renew the license?
* It's not very clear to me how to get a new license, should i go to: https://marketplace.zyxel.com/license/detail/Nebula Control Center select Nebula Control Center and select type "Nebula Professional Pack License 1YR for Nebula Devices" to be able to monitor my access points?
* Do i need a licence for each accesspoint?
Hi @Evert,
Welcome to Zyxel Community!
* Does my access point still work if i do not renew the license?Yes, the access point will still work, just would like to remind that if some PRO pack features like DPPSK/voucher was bound in the SSID, the SSID will not broadcast after the license expires.
Note: You'll need to disable the feature to have the SSID broadcast again.* It's not very clear to me how to get a new license, should i go to: https://marketplace.zyxel.com/license/detail/Nebula Control Center select Nebula Control Center and select type "Nebula Professional Pack License 1YR for Nebula Devices" to be able to monitor my access points?The purchase part is correct. After purchasing a license, the system will send an email to your email address including the license key and the SOP on how to register/assign the license.
For the monitoring part, you can still monitor the access points, but some features like the "Wireless Health" need a PRO pack license.* Do i need a licence for each accesspoint?Yes, all devices registered in the organization should have a PRO pack license to keep or upgrade to a PRO pack.
Jonas,0
Hi @Evert,
Jonas,0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
