How to setup complete VPN solution for USG110?
Hi @mrwee
You can refer to this FAQ for setup L2TP VPN on different platform.
It include Windows/ IOS/ Android to setup L2TP VPN tunnel in your environment.
Also you can refer to handbook for different VPN types for different scenarios.0 -
Having 8 WAN IP addresses, I assume a physical or virtual WAN interface must exist? Seems like I can only define 4 virtual WAN addresses in additionl to wan1
You don't need to setup virtual interface for many wan IPs you use routing rules with SNAT
Hi @mrwee
In current design, user can only add up to 4 virtual interfaces per Ethernet interface.
So it means, you can configure 5 static public IP address on 1 WAN interface.
In VPN Gateway setting, "Interface" have to own the public address. And 1 interface can add multiple VPN rules.
The other 3 public IP addresses, you can create port forwarding rules or policy route with SNAT for different scenario.0 -
@Zyxel_Stanley Thought there were some kind of limitation. Can't get VPN to work, but I'll dig some more.
Hi @mrwee
What kind of VPN type that you would like to configure on your device? You may explain your scenario first, then we can give you some of suggestion.0 -
Sry, I can see that it wasn't that clear. I'm looking for enabling what I think should be (Not an VPN expert):L2TP/IPsec with IKE2 (Assume it's the most secure encryption) for e.g. iOS +Android + w10 / Zyxel VPN ClientSSL/SecuExtender when L2TP/IPsec is blocked/doesn't work.The lack of virtual wan interface, surely messed it up for me, when trying different things, but I still haven't managed to get my head around it0
Hi @mrwee
If you would like to setup and configure IKEv2 on Win10 & IOS client, you can follow this thread.
It has guide how to setup them on native client without others software.
According to L2TP/ SecuExtender are using for different protocol.
L2TP is using for IKEv1.
SecuExtender is for SSL VPN tunnel the packet is encrypted by HTTPS packets.0 -
Hi @Zyxel_Charlie ...And this brings me back to somewhat fragmented documentation.I (and hopefully others) would appreciate a complete "remote worker" manual, covering all these scenarios in one guide. If all was covered in one, it would probably also minimize the error risk in merging multiple configuration suggestions0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
