Notification doesn't work
Hi guys,
I think I need some help, I don't know what to do. Everything is set regarding to notification and it works for 2 years and from some time, I'm not receiving any email.
I checked logs and it says this "Sending event/alert log to mail server has failed."
Could someone help me with this issue ?
Thank you !
Regards,
Alex
Thank you !
Regards,
Alex
Hi @zappu
It looks your notification mail did not send out successfully.
You can make sure if your SMTP setting is correct first. (System > Notification > Mail Server)
If you are using Gmail, then you can have a check if you have enabled less secure app access setting to allow USG sends email by your account.
Then you can click "Send report now" button to trigger USG send mail.
And then go to check system log entries if mail has sent successfully.
Good morning Stanley,
Thanks for your info, it seems the issues it wasn't from there, after the previous firmwarware update, I don't know what happened, but the password for email account from GMail, has been changed in the Zywall 110. When I put the password and send a report I saw that it works.
In case if any have this issue, now he can know from where it is.
Best regards,
Alexandru Mavrodineanu0 -
Hi @zappu
It's good to know your issue has resolved. May we know which previous version was working on your device? Maybe we can have further check if issue is come from firmware upgrade.
Hi @Zyxel_Stanley,
Sorry for my late reply, I had a lot of work at work and then in the weekends most busy.
Regarding your question, the issue was appeared when I did the upgrade to this firmware version: V4.65(AAAA.0) on my Zywall 110.
Thank you !
Best regards,
Hi @zappu
What's the version is working on your device before you upgraded to 4.65C0 firmware?
Then we can have a test if password issue is came from firmware upgrading or others.0 -
Hi @Zyxel_Stanley,
I believe it was working with the previous firmware version, but when I have done the update of it the password has been changed. I don't know how and why it happened this, but as I said the issue I fixed in this version: V4.65(AAAA.0).
Thank you !
Best regards,
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 465 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
