VMG3925-B10B wifi channel select don't work correctly
#SP_Feb_2020
Have you tried to scan your environment to analyze the WiFi signal around your home?
From your description, it is suggested to contact Zyxel's local support team for a further support.0 -
Im having the same issue, fw version
V5.11(AAVF.3)C0
did you manage to resolve this?0 -
We're now in 2025, firmware V5.13(AAVF.17)C0
Problem has returned. For a while, auto channel has worked okay, but the problems with the 5 GHz band have returned as we now have proper summer again, which makes me suspect the router's antennae is incredibly temperature sensitive. When the router is rebooted, the 2.4 GHz band appears in available networks immediately, while the 5 GHz band can take up to 20 minutes to show up, if it shows up at all. According to the router's internal channel scan, channel 36-42 (80 MHz) are extremely busy in my building and when the router is set to auto channel select, those are the channels it always chooses, which makes the wi-fi unstable if it's even possible to connect. It's well documented on other sites that the wi-fi on this router is weak, but I'm talking about being no more than 3 steps away from it and failing to see any sign that the wifi is on at all, despite the router claiming it is.
- 243 Nebula Ideas
- 6.9K Security
- 786 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
