AX7501-B0, no acces to LOG
monsieur_cedric
monsieur_cedric Posts: 3 image  Freshman Member
edited September 2021 in Smart Home Product
Hey,
When I try to access the log section of my routeur, it just goes into an infinite loop (forever). So, it is impossible for me to check the log or export it.
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Try with another browser, if you can.
  • monsieur_cedric
    Thanks, it works on MS Edge, but the log is empty (System & Security). I tried exporting, it is just a blank page. Where is the log?
