Why is NSG100 LAN1 DHCP limited to 32 IP addr ???
I have a big site with 8 switches and 30 APs. The NSG100 Nebula Security Gateway does not offer IP addr to all network equipments, even if i extend the DHCP address range to 60. Is there a limit on the number of devices per site that an NSG100 can handle ?
Papa_DIOP - On the surface this doesn't sound right. Some questions come to mind...
- Is there another DHCP server on the network?
- Is DHCP set as the default on all the devices you are trying to get connected?
- Just from what you said, you have 38 devices that might be looking for an IP address PLUS all the other "stuff" connected to your 8 switches. Depending on how your configuring everything on your network, the 60 addresses you are allocating might not be enough.
Good luck.
-stew
Thanks, Ives. It's about the Management VLAN DHCP only which seems limited, whereby Network Equipments are supposed to fetch a Management IP addr. All other VLANs have DHCP running fine.0
Hi @Papa_DIOP,
Please provide the organization/site name and help to activate Zyxel support located at HELP > Support request, so I could have the privilege to check the current settings and status.
More likely, there is other DHCP server in the environment which using same VLAN with management.
ThanksJonas,0
- 588 USG FLEX H Series
- 477 News and Release
