Secomea Sitemanager connecting issues
joel_lallemand
joel_lallemand Posts: 2 image  Freshman Member
edited August 2022 in Switch
Hi all
We are trying to connect a secomea sitemanager 3529 on a LAN-Port on a GS1920-24 Switch. We never had problems connecting a sitemanager on different switch types. But the port on the zyxel switch suddenly goes down after connecting... Even there's no port-sec configured. Any ideas? Logs only shoes port down and up events.
Firmware on the GS1920 is V.4.3.0.a
Thanks for your help.
Best regards
Joel
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @joel_lallemand,
    Welcome to Zyxel community!
    Have you tried to configure port speed with force 100M full-duplex or 10M full-duplex on both secomea sitemanager 3529 and GS1920-24?
    The configuration page for the port speed on GS1920 is Basic setting > Port Setup.
    (You will need to access GS1920 via WebGUI)
    May you also share the complete firmware version of your GS1920-24?
    It can be found in the status page.
    (The screenshot below is just an example in the user guide.)
    Jason
  • joel_lallemand
    Hi Jason
    Thanks for you feedback.
    We already tried that without success.
    We have installed a cisco switch between the sitemanager and the zyxel switch - now it works fine. I also assume a negotiation problem between the other two devices.
    Best regards
    Joël
  • Zyxel_Jason
    Hi @joel_lallemand,
    It seems like an IOP issue between the sitemanager 3529 and GS1920.
    Thanks for sharing the workaround you found here.
    Jason
