What is the expected wifi speed for a USG60W?
usamarathoner
in Security
I am getting around 2.4G 27Mbps
Ethernet Wired WAN into the USG60W is getting 300+Mbps0
In default radio profile, channel width is 20 MHz.
You can change it as 20/40 MHz may get higher speed.
usamarathoner said:I am getting around 2.4G 27Mbps
Which network adapter are you using? In which zone is your WLAN?
Thanks for your answer. It looks performance may affect by wireless environment.PeterUK said:Then built in AP on the USG60W only support 20MHz on 2.4G
I get over 50Mb on 2.4G my USG60W depending on line of sight to it
Use 5G band may get better speed.0
- 603 USG FLEX H Series
- 480 News and Release
