Topology for Zyxel GS1920 48
Dear all,
I have seven switches in room 1-second floor. I also have 4 switches in room 2-second floor. There are 9 switches on the third floor. All switches are Zyxel GS1920 48. I wonder how to set up and topology for this scenario. Thank you very much
Best Regards
Best Regards
960 ports. Simple and straight class B Network? Reliability o maximize network throughput?
mMontana said:960 ports. Simple and straight class B Network? Reliability o maximize network throughput?
Dear, I have the problem that should I use Bus topology to connect switch by switch or using some method of redundancy. Thank you very much. Here is the diagram
Best Regards0 -
The idea is to reduce the single point of failure if the switch to the router goes down well so does everything but if any other switch goes down the rest of the network stays up.
Thank you very much for your answers, it means Star topology? The problem is that we have the same switch model, we don't have any distributed switch. Any solution for that case?PeterUK said:The idea is to reduce the single point of failure if the switch to the router goes down well so does everything but if any other switch goes down the rest of the network stays up.
Best Regards
Just use a GS1920 48 that all others connect too0
Hi @hunggggg,
Welcome to Zyxel community!
I would like to suggest another method.
If your router have three LAN port, you can connect your router to a switch in each of your room as aggregation switch and the rest of switches in each room may use star topology.
This method could make sure the network usage of room 2&3 if the switch in room 1 is down in the topology you provided.
If your router doesn't have three LAN port, you may use @PeterUK's solution.
Zyxel Melen0 -
Dear,Zyxel_Melen said:Hi @hunggggg,
Thank you very much for your suggestions. I have 2 types of diagrams here. I would be very grateful if you could point out some things wrong in my topology. We have the same switch model.
Best Regards
Nothing really wrong doing it that way.
This is the way I was thinking of.
https://embed.creately.com/43aBymYSHRN?type=svg
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
