SSL Inspection Crash (ATP700)
Julien_ALM
Julien_ALM Posts: 10 image  Freshman Member
Sometimes, SSL Inspection stop running on ATP700 (Firmware 5.02(ABTJ.1)) :
I have about (one-two hundred concurrent SSL session)
- SSL Inspection logs :
   SSL inspection daemon isn't ready!
  Creating session entry failed. Pass this session!
- Debugs logs :
  kernel: [1418384.809551] sslinsp_rcv_nl_event [3861]: SSL inspection daemon may be dead [Port ID = 0x66bc0000]
kernel: [1418384.961469] sslinsp_check_daemon [557]: SSL inspection daemon isn't running
  kernel: [1418386.949043] sslinsp_send_netlink_msg [35]: Cannot get SSL inspection daemon's PID:-1:
This service restart after. It happens about every week.
I Think this problem comes from the last update. (I Have never received alerts before)
Does anyone have the same problem ?
Thank You !
(Sorry for my english :) )
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Could you provide the config file of the ATP700 to us via private message for further investigation?
    Thanks.
