Fiber Media Converter with POE for WAC6553D-E
We need to deploy outdoor WLAN access point to be mounted at one of the lamp post.
Power outlet provided will be AC power inside a outdoor weather proof box.
Connection back to central switch will be using fiber optic cable due to the distance is about 1km.
Switch-SFP ——fo 1km—— SFP-Media Converter with POE —copper— WAC6553D-E
A) Media converter will use AC power adapter to connect to AC power at the lamp post to be housed inside the outdoor weather proof box.
Do you have a solution from Zyxel? Or other alternative solution for this application?
Hi @Amara
So far, Media Converter with PoE and SFP is not in our product series. But this requirement can be a feature request in our queue.
According to your requirement, we have PoE switch with SFP port. Here is the list for reference.dummy: GS1100-10HPSmart: GS1900-10HPManagement: GS2210-8HPThanks.
Joslyn0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
