[Release Note] Access Point Series - V6.25 P0 firmware has been released!
Access Points Firmware Release Note V6.25 Patch 0
Date: September 23, 2021
Supported Platforms
NAP203 V6.25(ABFA.0)
NAP303 V6.25(ABEX.0)
NAP353 V6.25(ABEY.0)
NWA1123-AC HD V6.25(ABIN.0)
NWA1123-AC PRO V6.25(ABHD.0)
NWA1123-ACv3 V6.25(ABVT.0)
NWA1302-AC V6.25(ABKU.0)
NWA5123-AC HD V6.25(ABIM.0)
WAC500 V6.25(ABVS.0)
WAC500H V6.25(ABWA.0)
WAC5302D-Sv2 V6.25(ABVZ.0)
WAC6103D-I V6.25(AAXH.0)
WAC6303D-S V6.25(ABGL.0)
WAC6502D-E V6.25(AASD.0)
WAC6502D-S V6.25(AASE.0)
WAC6503D-S V6. 25(AASF.0)
WAC6552D-S V6.25(ABIO.0)
WAC6553D-E V6.25(AASG.0)
NWA50AX V6.25(ABYW.0)
NWA55AXE V6.25(ABZL.0)
New Feature and Enhancements
1. New WiFi 6 AX1800 dual-radio Outdoor PoE Access Point is supported. This new outdoor AP designed for small business AP, NWA55AXE, comes with right-fit feature set, simplest configuration. It is IP55 weather proof rating, supporting Zymesh and wireless bridge features make it suitable for various semi-outdoor and outdoor applications for small businesses.
2. New feature, Client diagnostic, has added to Nebula Professional Pack. This feature is designed for easy troubleshooting as it summarized important events from the AP and get gateway (NSG/USGFLEX) in chronological order.
3. Radio output power configuration UI is enhanced. User now can select from different deployment types instead of only dBm setting.
Bug Fix
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 201200956] [Symptom] Root AP disconnects the repeater when the repeater keeps using the reassociation |
V |
V |
V |
2. [eITS: 210200191] [Symptom] clients keep disconnecting from the AP |
V |
V |
V |
3. [eITS: 201200268] [Symptom] SNMP OID location value is not update after applying |
V |
V |
4. [eITS: 210200396] [Symptom] the repeater is disconnected unless the root AP reboot |
V |
V |
V |
5. [eITS: 210200683] [Symptom] the station mac will show on the AP’s port as well but not only NXC port when using the tunnel mode |
V |
6. [eITS: 210100969] [Symptom] The AP is managed by NXC, and it was crash during collecting diagnostic.warning |
V |
7. [eITS: 210300399] [Symptom] When run commands in CLI User Mode systematically crash AP - show reference object-group aaa - show reference object-group aaa ldap |
V |
8. [eITS: 210300295] [Symptom] AP sent second stop message to the accounting server immediately when the station roamed from 5G to 2.4G |
V |
V |
V |
9. [eITS: 210300794] [Symptom] DCS does not work if configure as interval |
V |
V |
V |
10. [eITS: 210301207] [Symptom] The AP only transmits 5G radio due to less of wds_profile site_gen |
V |
V |
V |
11. [eITS: 210201226, 210201244, 210300970] [Symptom] wireless connection disconnected very frequency |
V |
V |
V |
12. [eITS: 210400270] [Symptom] NXC can’t apply configurations to AP |
V |
13. [eITS: 210401047] [Symptom] the station can connect to AP but failed to get IP address |
V |
V |
V |
14. [eITS: 210400252] [Symptom] 2.4GHz channel width becomes 20MHz after reboot |
V |
V |
V |
15. [eITS: 210401146] [Symptom] After AP upgrade to 6.20, the SNMP daemon is not enabled |
V |
V |
16. [eITS: 210500638] [Symptom] Can't login in nebula cloud in guest network |
V |
17. [eITS: 210501038] [Symptom] Rate limit upload not work with NAT |
V |
18. [eITS: 210301310] [Symptom] Channel width does not work as set |
V |
V |
V |
19. [eITS: 210601193] [Symptom] AP will show as repeater even if connected to Ethernet because AP can’t query 5GHz interface |
V |
20. [eITS: 210601357] [Symptom] Group Key Handshake Time out fail |
V |
V |
21. [eITS: 210700234] [Symptom] SSID not broadcast if change country to Korea |
V |
V |
V |
22. [eITS: 210701484] [Symptom] SNMP daemon not up due to configuration file sequence wrong |
V |
V |
23. [eITS: 210800145] [Symptom] when gateway is behind a NAT router, the RAP functions can’t work well |
V |
24. [eITS: 210900429] [Symptom] Socket leak after station authenticates |
V |
V |
V |
Known Issue
Mode |
CLD |
MGNT |
STD |
1. [eITS: 210400642] [Symptom] Mesh SSID is visible |
V |
2. [eITS: 210500147] [Symptom] SSID not broadcast after changing the forwarding mode from NAT to local bridge |
V |
3. [eITS: 210900596] [Symptom] Act-session ID in access stage is different to accounting stage |
V |
V |
V |
Release note release. Without firmware(s) release.What a unreleased release!0
Hello, yesterday i'd successfully updated AP WAX650S to this 6.25 firmware, but today, they want to downgrade to 6.20. It's a bug at 6.25?1
Same here. My Access Points also want to DOWNgrade the firmware (after upgrading to 6.25 yesterday). I experienced connection problems with my clients with the new 6.25 firmware since yesterday. So I considered a manual downgrade anyway.
Are there any infos about bugs in 6.25?0 -
Hi All,
We regret to inform you that new firmware release on 27th September has potential risk to cause client failed to obtain the IP address while doing intra-roaming within same access point (5GHz to 2.4GHz and vice versa). Client roaming between different access points DOES NOT have the same problem.
Please arrange the soonest schedule to revert AP firmware to previous version for ensuring smooth WiFi experience.
The issue only happens on following models NWA110AX, NWA210AX, WAX510D, WAX610D and WAX650S.
6.25 firmare is also expected for NWA-1123 V2 and NWA-5123, which I am aware that are not covered by this "delayed" release.
Any hint/suggestion/ETA for these devices?
Hoping the best for all other customers.0 -
Today, nebula offer me upgrade my WAX650 to new firmware from downgraded 6.20. new is V6.25(ABRM.1)
So far so good i'm upgraded one AP, other are scheduled to this evening.0 -
Same here with 6.25 on our WAX650S unit. After installation, soft reboot (and DCS) most connections would fail, especially on all 5GHz channels. Only a power cycle seemed to help, but again DCS caused problems on channels above 56, even though all clients could connect fine before.
After a second powercycle the AP worked fine for just a week, until a memory overload happend (>95%). Manual reboot didn't help, 2,4GHz worked but on 5GHz connections failed.
Downgraded back to V6.20(ABRM.1)-DF-2021-08-13 (FragAttack Hotfix). Problems gone. The WAX650S started to use channels above 64 again (DFS disabled). Connection speeds were higher again.
(We do not use Nebula for this unit)0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
