SSL Vpn problem
Hello
i have set a new SSL Vpne connection
But when i try to connect it read this error
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Checking service (first) ...
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] SecuExtender Helper is running
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Try to connect to SecuExtender Helper
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] SecuExtender Helper is connected
[ 2021/09/30 20:24:47 ][SecuExtender Agent][INFO] [summa] try to login xxxxxxxxx:443
[ 2021/09/30 20:24:47 ][SecuExtender Agent][INFO] Connect to xxxxxxxxx:443
[ 2021/09/30 20:24:47 ][SecuExtender Agent][INFO] Local address is xxxxxxx34
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DEBUG] Connect success.
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 0
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] 1275 bytes of handshake data received
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x90312
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Send 126 bytes of handshake data
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Handshake LoopCounter: 1
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] 258 bytes of handshake data received
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] InitializeSecurityContext returns 0x0
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] SSL Handshake is successful
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Protocol: TLS1.2
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Cipher: AES256
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Cipher strength: 256
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Hash: SHA384
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Hash strength: 0
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Key exchange: 0xae06
[ 2021/09/30 20:24:47 ][SecuExtender Agent][DETAIL] Key exchange strength: 256
[ 2021/09/30 20:24:47 ][SecuExtender Agent][INFO] Server subject: CN=vpn100_XXXX
[ 2021/09/30 20:24:47 ][SecuExtender Agent][INFO] Server issuer: CN=vpn100_XXXX
[ 2021/09/30 20:24:47 ][SecuExtender Agent][ERROR] **** Error 0x800b0109 authenticating server credentials! (0x0)
[ 2021/09/30 20:24:48 ][SecuExtender Agent][DETAIL] SSL session is created
[ 2021/09/30 20:24:48 ][SecuExtender Agent][DETAIL] Can't get authentication token(1)
[ 2021/09/30 20:24:48 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
[ 2021/09/30 20:24:48 ][SecuExtender Agent][ERROR] user login device failed (0x0)
[ 2021/09/30 20:24:48 ][SecuExtender Agent][DETAIL] Connection ends.
- 603 USG FLEX H Series
- 481 News and Release
