port: p2led has undefined status:orange
This is the welcome message after a login on a USG20-VPN upgraded to 5.10 (ABAQ.0).
Message appears any time i go to the DashBoard section, General Tab.
No Port led is lit on Virtual Device.
P2 is WAN1 interface, copper kind, Autonegotiate, 1000MPS Full. sfp, lan2, dmz are disabled and the setup is not going to change. P2 (Wan1) and P3 (Lan1) are the only connected cables, out of power.
This device entered service with a converted configuration from USG20 with latest 3.30 firmware (no WK48).
Game on, dudes
Issue disappear when the browser is restarted.Leds on virtual device also re-appear.5
Worth sharing the issue. Worth sharing the solutions. I don't think that can help that much (Zyxel documentation repeat in every upgrade procedure to refresh browser cache) but if someone look for the error... might find this solution.
2 -
After moving to another state, I now have the same error. Tried on different browsers, clearing cache etc. The physical panel shows orange LEDs for P2 (WAN) and P2, P3 (LAN). Any other suggestions to fix this? The virtual panel shows only green for Pwr and Sys.
Since clearing cache did not work, I reinstalled Firefox browser and the p2led error went away. I am wondering though why the LAN leds are orange now instead of green as they were before the move. I could not find anything in the documentation.0
Hi @Loek,
It's about link speed. Physical LED green means 10/100, orange means giga network.1 -
Well, that's a good thing! Faster is always better.0
- 588 USG FLEX H Series
- 477 News and Release
