DHCP Servers, DHCP Relay, VLAN and VoIP Configurations
hunggggg,
DHCP Server
For your scenario, apperently, your DHCP server will be set in your firewall.
DHCP Relay
The DHCP relay may be configured on the top left GS1920-48 as it is a aggregated switch when you configure more subnet in your network.
VLAN and VoIP
For configuring VoIP, you can configure Voice VLAN for VLAN10 and set PVID 5 to port 10 of the switch which connect to IP-Phone.
Hope it helps.Adam
- 441 Beta Program
- 293 Service & License
