Connecting multiple GS1920-48 Switches via SFP
Hi @Mike_M
If you just need to do some basic settings, I will recommend you to use ZYXEL ZON Utility.(link)
ZON can scan different switches in the same broadcast domain an do some basic settings, for example, changing IP address, doing firmware upgrade.
The software looks like:
If you will need more advanced setting on GS1920, you have to access these four devices, respectively.
Furthermore, another solution is to use switches supporting stacking, such as XGS2210, XGS3700, XGS4600 series.
Ryan0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
