nwa210ax & PoE12-HP. PoE not working.
Could you please try to boot it up with power adapter?
Besides, you can also try to press the reset button on the back panel of the AP.
If you don't see AP LED blinking/on, this can't directly link to AP's power off. since the LED can be suppression and not shown(configured by previous user). You can reset the AP to disable this setting.
Hi @Cossen
The AP flashing in green and amber is stands for the stage of boot up.
As Greenlight mentioned, the LED status can be configured as suppression.
Please reset AP by push the button on the device, with default settings, the LED is on and AP will broadcast SSID “Zyxel-XXXX” which is the last four letters of MAC address.
It is a way to monitor if the AP boots up and works properly.
If above method no success, can you use adapter or swap the AP to other ports on switch for testing. Then use a PC connecting to same switch and establish ZON to scan device.
https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
We’d appreciate your feedback when you have done above steps.
Thank you
Regards,
Bella
Zyxel_Bella said:
Hi @Cossen
It is a way to monitor if the AP boots up and works properly https://applinked.me/ .
Thank you
Regards,
Bella
Thank you very much for the solution. It solved the problem.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
