SSL vpn separate SSL vpn profiles
GrahamWebb
GrahamWebb Posts: 27 image  Freshman Member
Hi at the minute we use SSL VPN on our USG 500 Flex.  Users are allowed access a common set of address objects, basically the servers on our LAN that they need to access.
I have a new user starting that will be using his own PC from home to do graphic design.  Is it possible to setup a second SSL vpn just for that user so that when he connects to the VPN he can only access the server he requires for artwork?
I see on the SSL VPN 'Access Priviledge' page there is an option to add multiple VPNs so is that how this could be done?.
Thanks Graham
  • Zyxel_Emily
    You can create a new "Access Policy" in VPN > SSL VPN > Access Privilege for the new user to access a specific server/subnet.
    In this example, the SSL VPN rule "New2" is for the new user.
     Move the new user to "Selected User".
    In Network List, allow the IP address/subnet of the specific servers only.
