GS1900-24 and VLAN ID 1
Hello Everbody!
I have a question regarding VLAN ID1 on my Zyxel switch.
As there seams to be an issue when using VLAN ID1 with my Sophos UTM I would like to diasable (and if possible remove) VLAN ID1 on my Zyxel switch and use ID10 instead. Unfortunalty as soon as I remove all ports from ID1 (set to excluded) and move to ID 10 (untagged) instead the communication stops. What is the reason for this? All information I found on the web is always using VLAN ID1.
Thank you!
Volker
Best Answers
Hi @VoRe,
Since the VLAN1 can't be deleted, you just need to set VLAN1 to "Excluded" or "Forbidden" for every port to avoid receiving VLAN1 packet.Zyxel Melen1
Hi @VoRe,
Welcome to Zyxel Community!
I think the reason is that you only changed the VLAN port setting but you didn't change the PVID and the egress setting might not correct.
I suggest to set one port's PVID from 1 to 10 before you change VLAN setting, this allow you can access switch Web GUI after you change VLAN setting.
May you also share your VLAN setting(port and VLAN port setting) and topology?
Zyxel Melen0 -
Hello! Attached some screenshots. I tried again a few minutes agop. As soon as I change the PVID from 1 to 10 I can't access the Webgui of the GS1900-24 any more. On port 1 and port 2 I have connected two more Zyxel switches in another part of the building (2x GS1900-8HP). Do you need some more details?
Best regards
Thanks for the answer.. this solved my problem. I expected something like this but I overlooked this option. Is it necessarry/possible to delete VLAN1 (can't delete it)? Or is it OK to just set VLAN1 to "Excluded" for every port?
Hi @VoRe,
Since the VLAN1 can't be deleted, you just need to set VLAN1 to "Excluded" or "Forbidden" for every port to avoid receiving VLAN1 packet.Zyxel Melen1 -
Is there a reason you dont use LAG/LACP in this setup?
is there a reason you dont use LAG/LACP?
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 647 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 55 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 93 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
