ZyWALL ATP configured L2TP VPN. Windows 10 doesn't connect.
I configured the L2TP VPN using: CONFIGURATION > Quick Setup > VPN Setup Wizard > VPN Settings for L2TP VPN Settings, and L2TP worked fine. Windows 10 was connecting.
And then I wanted to make sure that only certain users could connect. And created a group for VPN connection. In the Configuration > L2TP VPN > User, I specified a group for VPN connection:
And Windows 10 stopped connecting, error: "Unable to connect .... so the connection port is closed.
SA Life Time: 86400
Mode: Main
Proposal: 3DES-SHA1
Key Group: DH2
Phase 2 settings:
SA Life Time: 86400
Protocol: ESP
Encapsulation: Transport
Proposal: AES256-SHA1, AES128-SHA1, 3DES-SHA1
PFS: none
For L2TP connection "pre-shared key" and "user name and password" are used.
Configuring the built-in Windows 10 client:
What could be the problem?
When I go back to the original configuration, everything works fine, Windows 10 connects.
I used these settings, because Windows 7 needs to be connected:
Phase 1 settings:SA Life Time: 86400
Mode: Main
Proposal: 3DES-SHA1
Key Group: DH2
Phase 2 settings:
SA Life Time: 86400
Protocol: ESP
PFS: none
Log IKE: isakmp sa [...] is disconnected
send:[hash][del] [count=3]
Dynamic Tunnel [...] built successfully
You can reference this thread
https://businessforum.zyxel.com/discussion/4532/how-to-setup-l2tp-vpnMake sure IKE and AuthIP IPSec Keying module is enable on PC.
Jeremylin said: You can reference this thread
Thank You. The L2TP works. But it shows an error in the Log IKE:The cookie pair is : …
Send:[HASH][DEL] [count=3]
Tunnel […] is disconnected
Recv:[HASH][DEL]
Dynamic Tunnel [...] rekeyed successfully
And so everything repeats. Is this the way it should be or is there a problem somewhere?
Hey ilnaz, did you ever find the sollution??
We have a similar issue. We also get the "disconnected" and "[HASH][DEL]"
We can even see in in the logs:
Then some rekeying and finaly a "Recv:[HASH][DEL"...Dynamic Tunnel [...:....:0x33029178] built successfully0 -
沒有進步的公司幾十年了還是一樣
把複雜變成簡單,
你們卻是倒過來 ,, 越來越複雜...
這些事務 只是軟體..經過時代變遷 ...這些沒有任何意義..它只是設備 只是設定..
並不能讓用戶去輕易使用...0 -
ilnaz said:Jeremylin said:You can reference this thread
Recv:[HASH][DEL]
沒有必要去搬石頭砸自己的腳0 -
Zyxel_Vic said:
VPN PPP /L2TP
IOs / 安卓 >>OK
Windows 7/8 >> 無法使用
windows 10 須更新...
反觀其它廠牌路由器防火牆產品 ...不需要花太多時間在這上面...
Windows 7/8/ 10/ ios /安卓 /平板
你們幾十年了...一成不變..沒有進步...
反而將設置 變得更複雜...
資訊化的目的是簡化 ,而不是複雜化..
而你們的反其道而行...它只是軟體和設定...時代的變遷..這些東西毫無意義...
讓你們的用戶花更多時間在找Q&A 去解決處理你們產品的問題...
浪費時間和效率 把時間浪費在 設定操作上...
資訊化的目的是簡化 ,而不是複雜化..
承上問題..
使用其它廠牌....以上的問題Windows/7/8/10 /ios/安卓 /平板,可以在最短的時間有效率地處理問題.
公司是營利事業單位, 不是來買你們的產品 再來找 Q&A解決問題....
給你們參考
說的真...
對你們的產品相當失望0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
