Any firmware updates for Armor G5
For the first test, performance and bandwidth are really better! Was a long way to go but thank youZyxel_Jerry said:Hi @Asgatlat
On the device web gui, you can click check firmware and update to the latest firmware.
The release note will be updated in these days.
For the next FW update you should try to speed up the boot process (veryyyy long compare to other brand)1 -
Hi Coen,CoenB said:NBG6818 (armor g1) firmware "v1.00(ABSC.5)C0" installed.
enabling remote assistant (wan+lan, port 443) does not seem to work (goes automatically to 'disabled' again)
It should work on the web GUI, please clean the cache on the browser or try to use other browser to login and check it again.
For the feature request, we'll evaluate the feature.1 -
Any chance you will release the firmware for open source or allow OpenWRT (or similar) to be installed? would help implementation times greatly and probably increase sales as the hardware is great and that community is huge.0
Thank you for the reply, I hope you do consider it as it would make this the ultimate device.1
I join in the wish, with such hardware there will be greate deviceZyxel_Jerry said:
Official firmware seems to be based on OpenWRT 15.05.1 so isn't it the case that not releasing source violates OpenWRT license?
Hi @Evlo
You can refer to the End-User License Agreement
To get the open source code, you can send Open Source Code request to us.
https://www.zyxel.com/form/gpl_oss_software_notice.shtml
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 324 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 458 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
