Any firmware updates for Armor G5
  • Asgatlat
    Asgatlat Posts: 139
    First Comment Friend Collector Ninth Anniversary
    image  Ally Member
    Hi @Asgatlat
    On the device web gui, you can click check firmware and update to the latest firmware.
    The release note will be updated in these days.
    For the first test, performance and bandwidth are really better! Was a long way to go but thank you :)
    For the next FW update you should try to speed up the boot process (veryyyy long compare to other brand)
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406
    image  Zyxel Employee
    CoenB said:
    NBG6818 (armor g1) firmware "v1.00(ABSC.5)C0" installed.
    enabling remote assistant (wan+lan, port 443) does not seem to work (goes automatically to 'disabled' again)
    Hi Coen,
    It should work on the web GUI, please clean the cache on the browser or try to use other browser to login and check it again.
  • Zyxel_Jerry
    Asgatlat said:
    Hi @Asgatlat
    Thanks for your feedback.
    For the feature request, we'll evaluate the feature.
  • davedave1234
    davedave1234 Posts: 3
    image  Freshman Member
    Any chance you will release the firmware for open source or allow OpenWRT (or similar) to be installed? would help implementation times greatly and probably increase sales as the hardware is great and that community is huge.
  • Zyxel_Jerry
    Hi @davedave1234
    Thanks for your suggestion.
    We’ll evaluate the feature.
  • davedave1234
    Thank you for the reply, I hope you do consider it as it would make this the ultimate device.
  • Ghost777
    Ghost777 Posts: 12
    Friend Collector First Anniversary
    Hi @davedave1234
    I join in the wish, with such hardware there will be greate device
  • Evlo
    Evlo Posts: 4
    Official firmware seems to be based on OpenWRT 15.05.1 so isn't it the case that not releasing source violates OpenWRT license?
  • Evlo
    Evlo Posts: 4
    edited October 2022
  • Zyxel_Jerry
    edited October 2022
    Hi @Evlo
    You can refer to the End-User License Agreement
    To get the open source code, you can send Open Source Code request to us.
    https://www.zyxel.com/form/gpl_oss_software_notice.shtml
