XS1930-10 to XS193012-HP SFP+ Link aggregation
jpikoulas
jpikoulas Posts: 2 image  Freshman Member
edited August 2022 in Switch
Is it possible to XS1930-10 to XS193012-HP SFP+ Link aggregate? I have connected both SFP+ ports on both switches, and they seem to be up, but when I go to Nebula I can see on the XS1930-10 that one of the two SFP+ ports is "STP blocking" status, and the other SFP+ port is marked as "Uplink". On the XS1930-12 none of the two SFP+ ports are marked as "Uplink".
Regards,
John
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @jpikoulas,
    Welcome to Zyxel community!
    Yes, it is possible to set Link aggregate between XS1930-10 and XS1930-12HP via SFP+.
    The reason that one of SFP+ port been blocked by STP is that STP function is enable by default and you did not enable
    Link aggregate before connect two SFP+ ports cause loop.
    Please follow the picture below to setup
    Link aggregate:
    The example switch is XS1930-12HP
    I suggest to set LACP so you may have redundancy.
    Don't forget to set Link aggregate on both your switches.
    When you finish setting, remember to enable the port you disabled in first step.
    Hope it helps.
    Zyxel Melen
