USG210 admin password
Pin the reset button on the front panel for 10 seconds and it will reset your admin password.1
All of configuration be reset.
If you would like to keep your configuration, you can follow these stpes to backup old configuration and reset admin password.
https://community.zyxel.com/en/discussion/1558/how-to-backup-running-configuration-if-forgot-password
Why does this happen? This has just happened to me for the 2nd time in the last few years and it's very annoying to have to reset and restore our config.0
Hi @jw708
Did you configure character doesn't belonging to ASCII code?
Which firmware version occurred the issue? You can upgrade to latest version(4.71) first and make sure if it helps. New firmware could backup configuration by schedule and send to your mail server. Restore configuration steps is much easier than previous steps.
- 603 USG FLEX H Series
- 481 News and Release
