[NEBULA] Is it possible to enable NAT Loopback (hairpinning) on NSG?
Is there some way to enable NAT Loopback (Hairpinning) on a Nebula Security Gateway (NSG) so that I can use a domain name to connect to a NAS from on the LAN? There is a checkbox dedicated for this in the Zywalls’ web interface, but I can’t find any similar feature in neither the Nebula Control Center nor the built-in web interface.
Best Answers
Hello @nikka
Welcome to Nebula Community!
By default setting NSG will enable NAT loopback function, you don't need to configure it, is it still have the issue?
Is your client host and server located in the same subnet?5 -
Hi @nikka
One more thing I forgot to mention, if your Public IP set any, then NAT loopback will not work, you must specify the IP for it.
5
Hello @nikka
Hi @nikka
5 -
I see. That was my problem! Thanks a lot!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
