[NEBULA] Bandwidth Control by Port
raymundoalvarez
raymundoalvarez Posts: 1 image  Freshman Member
Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Security Eighth Anniversary
edited April 2021 in Nebula
Will there be ability to control bandwidth by Port on a Nebula Switch?  We do not see it on the roadmap.
This is important if the switch is being used to segregate networks speeds.
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    edited June 2018
    Per port bandwidth control will be available on both Hybrid & NSW around the end of this year.
    Devices will need a firmware upgrade then.
    Please note that this feature is in Professional Pack, that is, you will need to buy the license to use it. :)
    Hope it helps.
    Jason
Nebula Tips & Tricks
