SSID removal and MAC filter rule removal issue on USG20W-VPN v5.10
I have encountered two new wifi issues with our USG20W-VPN after upgrading to v5.10.
1. How to remove an SSID after adding it? There is no remove button.
2. After adding MAC filtering in SSID it seems no longer possible to remove any added MAC filter rules because they just keep coming back after removing them, pressing OK and then apply. Nothing happens.
Does anyone else have this problem or may have a solutions for the moment?
Hi @Ensto
The delete button was removed since 5.XX due to some design changes. However, you can still add, edit, activate, and inactivate those SSID profiles instead. We will evaluate if this should be put back in the future. Thanks for your feedback.
Regarding MAC filtering profile can't be removed symptom. We addressed this should be an issue. We will arrange on this issue fixing.
Hi @Ensto
Hi @Zyxel_JeffZyxel_Jeff said:Hi @Ensto
Thanks for the answer
Ok, then i'II wait for the MAC-filter fixes. You also have my vote for putting the remove button back for SSID because I think that at least everything that is custom addable always should be removable as well to achive that nice and clean config we all want
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
