[NEBULA] STATIC DHCP TABLE
roy
roy Posts: 19 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Nebula
I have been working on my new NSG50 for several days, but didn't work out.
There are so many problems I can't solve. A thing I feel it is quite basic is static DHCP table.
I don't want to mention the interface the NCC provided is so bad, I keyed in the MAC addresses to the table, but result is client computer still get dynamic ip address, not the one I made for them.
If I can't get the the ip address, I can't set the firewall rule for them......
Furthermore, this firewall rule setting is so so basic.... I know what I bought this one is the basic kind, but this was far from my basic expectation....
I'd like to ask some experts, have you met this issue? How to solve it?
Cheers,
Best Answers
  • roy
    I removed all the list and remade it. It works!
    Thank you very much!!
  • roy
    The client still got the previously dynamic ip address, not the designated IP I set in the static DHCP table.
    The strange thing is that I disabled the DHCP function in the interface, the client still got the IP.
    I made the DHCP ip pools from 192.168.1.50, pools 20, but the client got 192.168.1.36.
  • roy
    I have met so many problems. I wondered if there is firmware to fix it? Will the NCC upgrade the firmware automatically?
  • roy
Nebula Tips & Tricks
