ZDL4.70 AAPI.0 - USG210 - SSLVPN disconnect right after connection
Hey,
last night the auto update installed the latest version of the firmware.
This morning the SSLVPN doesn't work anymore.
The users gets disconnected right after connection.
Is there a solution to solve this without rebooting the firewall, or put it back to the old firmware?
We are on the start of our work day, + 100 users are connected to the firewall.
And a lot are working from home due to covid.
Thanks a lot for the tips!!
Greetings
Stef
Greetings
Stef
Your device should have a double partition, and if managed correctly you should have version 4.65P1 in your "standby" partition.0
AFAIK no way. Sometimes 10 minutes of downtime is better than no service at all.Ensure yourself that standby partition have the version you need.0
Oké, thanks.
I will wait until this evening to reboot.
The VPN problem is not big enough to disconnect the internet for that periode.
Maybe the reboot will solve the problem, otherwise the standby partition will do it.
Greetings0 -
I updated today 6 devices. 3 rebooted, 3 pending...
Reboot didn't help
So i changed to 4.65P1, and now it works again.
Disabled the auto update
Hope the problem will be fixed in the next update.
Thanx0 -
Sorry to read that. Did you take a read on release notes?
Hi @OTADMIN
I have a tested in 4.65P1 firmware, and SSL VPN tunnel seems works without problem.
I will send you private message for further check this issue directly.
I updated my USG 310 gateway to firmware 4.70, everything is fine with ssl vpn. Users connect without problems.
hi everyone.
is another person had this problem ? i'm affraid to update to 4.70 (i'm on 4.65 P1)0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
