nsa320 jbod to raid 1
jko
I tried converting adding a brand new drive to convert to a single disk jbod.
cat /proc/mdstat shows the recovery goes to about 70% and then stops. Any ideas what is wrong? The new drive is 4tb and old one is 3tb, but that shouldn't matter should it?
# mdadm -D /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Tue Nov 9 08:47:57 2021
Raid Level : raid1
Array Size : 2929765240 (2794.04 GiB 3000.08 GB)
Used Dev Size : 2929765240 (2794.04 GiB 3000.08 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Update Time : Tue Nov 9 19:27:07 2021
State : clean, degraded
Active Devices : 1
Working Devices : 2
Failed Devices : 0
Spare Devices : 1
Name : NSA320:0 (local to host NSA320)
UUID : 929b9738:5666172e:bdf6015e:f0ef83cd
Events : 7195
Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
2 8 34 1 spare rebuilding /dev/sdc2
~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1]
md0 : active raid1 sdc2[2] sda2[0]
2929765240 blocks super 1.2 [2/1] [U_]
unused devices: <none>
I think you have a Current_Pending_Sector issue on your original disk. Did you plan to also exchange the original disk by a 4TB one? In that case you could create a new JBOD on the new disk, copy the files over, and convert the new JBOD to raid 1 with the 2nd 4TB disk.
No, it shouldn't matter.
2 8 34 1 spare rebuilding /dev/sdc2The headers says it's rebuilding, and /proc/mdstat says it's not? Did you hotplug that disk? Is there an /dev/sdb? (cat /proc/partitions).I wonder if there is some 32 bit issue (70% of 3TB = 2.1TB = 2TiB, which is the 32 bit limit of SATA addressing).Does dmesg give a readable message about the synchronization stop?0 -
disk wasn't hot plugged and the partition exists. Didn't see anything in dmesg, I tried it twice (reformatted the new drive between each try), both times stopped around the same time.
I see the original product description says up to 2 3TB drives, not sure if there's an actual 3TB limit.
~ # cat /proc/partitionsmajor minor #blocks name7 0 140288 loop08 0 3907018584 sda8 1 498688 sda18 2 3906518016 sda28 16 2930266584 sdb8 17 498688 sdb18 18 2929766400 sdb231 0 1024 mtdblock031 1 512 mtdblock131 2 512 mtdblock231 3 512 mtdblock331 4 10240 mtdblock431 5 10240 mtdblock531 6 48896 mtdblock631 7 10240 mtdblock731 8 48896 mtdblock88 32 3907018582 sdc8 33 131072 sdc18 34 3906885632 sdc29 0 2929765240 md00 -
Something fishy is going on. Your box has 3 disks connected, sda 4TB, sdb 3TB and sdc 4TB.sda and sdb seem to be 'zyxel' disks, as they have a first partition of 498688kB, and a 2nd spanning the rest of the disk. Your sdc has a 1st partition of 131072kB, which is not zyxel.You write you are trying to create a raid1 array of an existing 3TB disk and an empty 4TB. The array is build from sda and sdc, both 4TB, and sdc as shown here should not be a part of that array.I see the original product description says up to 2 3TB drives, not sure if there's an actual 3TB limit.No, there is no 3TB limit. At the moment the 320 was launched I suppose only 3TB disks were available (for a decent price) and so they were the only ones tested. I'm pretty sure I have read reports of bigger disks (8TB?) inserted in a 320, so there is no artificial 3TB limit. An non-artificial limit will not be 3TB, but a power of 2. (And there is a limit of 16TiB, by the filesystem limit of 2^32 clusters of 4kB each).
The 3rd disk is unrelated and is connected through external USB.0
In that case I'd retry with the USB disk disconnected. Your array consists of sda2 and sdc2. In Linux disk names are assigned in the sequence the disks are found, and as the SATA bus and USB bus are not initialized together, it's very unlikely the USB disk would be sdb. It should be either sda or sdc.
tried without the usb, it still failed. But this time I did see an error in dmesg which said "unrecoverable I/O read error for block ". Although smart and the scan in zyxel's UI shows the disk is ok.0
Thanks, that'smy guess too. The plan is to get a new 4 bay nas around Thanksgiving and then copy things over0
- 238 Nebula Ideas
- 6.8K Security
- 750 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
