Is this a good 16 port gigabit switch? If not, what are some good recommendations?
I don't have gigabit internet but want to future proof this purchase.
Also, do I connect the ethernet wire from the modem into any of these slots, and then I connect a Ethernet wire from the switch to the router?
Or do I cinema hd connect the ethernet wire from the modem to the router, then a wire from the router to any of these slots?
You connect a modem to router then router to switch usually.
The GS1100-16 is a fine Unmanaged Switch0
- 441 Beta Program
- 293 Service & License
