Is this a good 16 port gigabit switch? If not, what are some good recommendations?
ksleinwe
ksleinwe Posts: 1 image  Freshman Member
edited August 2022 in Switch
I don't have gigabit internet but want to future proof this purchase.
Also, do I connect the ethernet wire from the modem into any of these slots, and then I connect a Ethernet wire from the switch to the router?
Or do I cinema hd connect the ethernet wire from the modem to the router, then a wire from the router to any of these slots?
    PeterUK Posts: 4,264 image  Guru Member
    edited November 2021
    You connect a modem to router then router to switch usually.
    The GS1100-16 is a fine Unmanaged Switch
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    Nothing wrong with having a gigabit internal netwerk, no matter which bandwidth your uplink to internet has. The devices in your network can talk at gigabit speed to each other.
