customizing SecureReporter report
Orad
I've finally got content filter to log all sites and SSO to tag all the users that access them. Now i have too much information, with microsoft sites being dominant in the log. Is there a way to exclude certain URLs from the log?
and i wasn't able to find a way, to send URL access log only. I can edit my daily log config and select Web Content filter Top allow or block. but not the whole list of accessed sites, just as i see them in Search Log - Network Activity - Web Content.
Is it possible to do so?
Thank you
Thank you
Hi @Orad,It does not support at current design, thanks for valuable suggestion.
The feature is confirmed in our roadmap.0 -
Thank you @Zyxel_Cooldia
for your reply. Do you know if its possible to pull that data from device logs and how would i do it?0 -
Hi @Orad
You can set up syslog to send device log to syslog server or attached a USB to firewall to archive log.
CONFIGURATION > Log & Report > Log Settings
- 441 Beta Program
- 293 Service & License
