Device Insight Management
[Deleted User]
in Security
How can you remove devices that were previously discovered by the Device Insight service?
You missed space between e and _0
I enabled the Device Insight option to see what it can do for me. After running it for a few weeks I didn't see a lot of value add in my particular network. It also used up CPU cycles that I couldn't afford to lose. I have since disabled the Device Insight option on my USG. However, when I go into the USG under "monitor", "Network Status", "Device Insight", the list of discovered devices is still populated in the list. I was wondering how to return the USG to show nothing in that list as if I never enabled it. This is purely a housekeeping item for me. I was hoping there was a command to flush the device insight table perhaps of devices no longer reporting? It there a table keep alive?0
When I issue that command, I get the following error:
Router(config)# device_debug flush device-list% (after 'terminal'): Parse errorretval = -1ERROR: Parse error/command not found!Router(config)#0 -
Thank you!0
If you do the above, is that permanent or will the list populate again after enabling Device Insight again?
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
