Bandwidth control
conglymingyang
conglymingyang Posts: 2 image  Freshman Member
when my site used to Pro Pack, I have open Bandwidth control for the port in the switch, but now My site is no more use to Pro Pack , I can't disable for Bandwidth Control Port. can help me check
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @conglymingyang,
    It is normal behavior that bandwidth control feature will keep the setting but can't configure on the Switch after the license is expired.
    If you can't renew the license currently for some reason, you may need to move the end device to the port which doesn't enable bandwidth control.
    Hope it helps.
    Jason
  • Zyxel_Jason
    Hi @conglymingyang,
    Hope it helps.
    Jason
Nebula Tips & Tricks
