Unable to unencrypt emailed config files from USG FLEX 500.
nialloreilly
nialloreilly Posts: 1 image  Freshman Member
First Anniversary
Greetings Support,
My USG Flex 500 [FW: 5.10(ABUJ.0)] emails out the configuration file on a daily basis, with the Encryption password enabled. When the email arrives in I'm unable to unencrypted the file using the assigned password. Selecting the "unmask" button shows me the applied password, which is the same one I use to unencrypted. I have now removed the Encryption password, doing this allows me to read the configuration file attached to the email.
Any assistance appreciated.
Niall
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited November 2021
    Hi Niall
    I can extract the config file with password "1qaz@WSX".
    Could I know what kind of password you used ? Or you could send private message to me.
    I will try to reproduced the symptoms.
    BR.
    Kevin
