all network card lights off
Hi, now i have another big problem; After a period where everything seemed to be working now this happens: the firewall works regularly for a while then the lights of the network cards go out and the only system is to unplug and restart the firewall because it does not connect to the web interface and not even ping.
Which device is having the issue you describe?0
Usg2100
Hi maybe i found what may be the problem: high cpu usage.
can anyone help me?0 -
@LeviPonti CPU usage 50% is not quite high. When the lights of the network cards go out, is there anything wrong with the traffic go through the firewall? Is the whole device frozen? Try to connect serial console and see any abnormal messages appear on console.0
the whole system is blocked. the ssh connection is also dropped.
a few moments ago the problem recurred and by diverting some subnets to another outlet the lights of the network cards came back on and the firewall started working again.
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
