VLANs cant communicate with LAN
Hi Community,
I dont have experience about VLANs. I followed the instructions how to set up VLANs. Now my test-VLANs can communicate with each other as I wanted but from and to LAN there is no communication possible.
I have an XGS1930 (Layer 3). LAN is 192.168.1.0, VLAN10 is 192.168.10.0 and VLAN11 is 192.168.11.0.
Do I have to have a router or is it possible without that everyone can communicate with everyone? I guess that my problem is the missing routes.
My reason to create VLANs is that I dont have enough IP-addresses in 192.168.1.0 anymore. So I would like to create new subnets for a few departments.
Thank you very much for your help.
Fritz
Fritz
FritzS said:I have an XGS1930 (Layer 3).
LAN is 192.168.1.0,
Depending on how you configure ports, by a logical point of view, 3 LAN/VLAN = 3 switches.
With a VLAN-Aware router and appropriate configuration you can manage connection between the three VLANs with only 1 port connected, but this solution caps the max throughtput to the one of the port used.
10GBPs if you use SFP+ port
1GBPs if you use 1GbE port.0
LAN is 192.168.1.0,
1GBPs if you use 1GbE port.0 -
Hi mMontana,
Thank you so much for your help!0
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 438 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
